Door Lock Switch Kit
$379.00
3 lbs.
The Door Lock Switch Kit reduces risk by allowing you to lock enclosure doors during potentially hazardous machining operations.
The Door Lock Switch Kit reduces risk by allowing you to lock enclosure doors during potentially hazardous machining operations. Its high-force lock mechanism makes sure the doors stay closed, and its plug-and-play integration enables you to quickly install it on the enclosure.
- 1100M
- 1100MX
- 770M
- 770MX sold before December 1, 2025 with serial number beginning with MF or MH
- PathPilot 2.1.6 or later
Requirements
- Mill enclosure
What’s In the Box?
- Door switch
- Mounting hardware
*Not compatible with 770MX mills sold after December 1, 2025 with serial numbers beginning with ML.
