Dual contactor kit with M12 connector and backing plate
$219.00
1.5 lbs.
Only 2 left
For use with ZA robots - two 24VDC contactors capable of switching 10A AC/DC load
Dual contactor kit includes two 24VDC contactors, each capable of switching 10A, mounted to an aluminum backing plate with M12 connector for use on ZA robot digital outputs.
Specifications:
- Relay Coil rated voltage : DC 24V
- Relay Coil power consumption: 1.4W each
- Rated current :10A
- Rated contact capacity :
- Resistive load : AC250V/10A Or DC 30V/10A
- Inductive load : AC250V/5A Or DC 30V/5A
- Contacts : 3 C/O changeover contact
What's in the box:
1 contactor kit (two 24VDC contactors capable of witching 10A each) mounted to an aluminum backing plate with M12 connector for use on ZA6 robot digital outputs.
