Electrical Noise Suppression Kit
$25.95
0.5 lbs.
Only 3 left
The Electrical Noise Suppression Kit includes 3 RC (resistor/capacitor) filters to effectively suppress electrical noise generated by the on/off operation of machine contactors and any external equipment connected to the switched convenience outlet (coolant outlet)
Important Compatibility Note: This Electrical Noise Suppression Kit applies only to Tormach machines manufactured prior to May 2013. All PCNC models built after May 2013, as well as all Tormach lathes, routers, and all M- and MX-series machines, already include these or equivalent noise-suppression components from the factory and do not require this kit.
3 RC (resistor/capacitor) filters to effectively suppress electrical noise generated by the on/off operation of machine contactors and any external equipment connected to the switched convenience outlet (coolant outlet).
  • Strongly recommended for use with inductive devices such as pneumatic valves, electrical motors, etc., as they can introduce machine control problems.
  • Kit, some basic assembly is required.
