Electronic Tool Setter with Mounting Block
$1,685.00
4 lbs.
The Electronic Tool Setter saves setup time and improves machine accuracy by automatically measuring and setting tool lengths.
Quickly and accurately measure tools and job setups with the Electronic Tool Setter (ETS). In addition to setting the work offset’s Z position, you can use it to make corrections for thermal variance and even check for broken tooling. Features include:
- Polished carbide touch plate
- Sealed contacts
- LED indicator light when triggered
- Armored cable
- Plug-and-play integration with PathPilot controller
- IP68 rated
- 1100MX
- 770MX*
- 1100M
- 770M
- PCNC 1100
- PCNC 770
- Not Compatible with 770MX mills sold after December 1, 2025 serial numbers beginning with ML or 1500MX mills.
Requirements
- PathPilot controller
NOTE: You do not need to remove the ETS from the machine when using flood coolant.
What's In the Box?
In addition to the tool setter, items include:
- Riser block
- 3 mm hex installation wrench
- M4 socket head cap screws (two), 25 mm long
- Protective storage case with fitted foam lining
Specifications:
| Sensing Logic | Normally open |
| Repeatability | 0.000078 in. (0.002 mm) |
| Maximum Over-Travel In +Z | + .1968 in. (5.0 mm) |
| Parallelism Between Working Plane and Bottom Surface | 0.00039 in. (0.01 mm) |
