Enclosure Door Switch Kit for PCNC 1100 / PCNC 770
$335.00
1.25 lbs.
Only 3 left
The Enclosure Door Switch Kit for PCNC 1100 / PCNC 770 (Series 1-3) is an optional switch that limits maximum spindle speed when enclosure door is open
Enclosure Door Switch Kit for PCNC 1100 / PCNC 770.
This is an optional safety switch that will pause a running G code program and limit the spindle RPM to a value settable by the machine owner. Default RPM with the enclosure door open is 1000, but can be set to any value from 0 to the machine's maximum RPM. When not running a program the machine is still capable of movement (jogging or MDI command) with the door open.
  • Compatible with PCNC 1100 and PCNC 770 Enclosure Kits, (PN 34427 / PN 34442)
  • Some assembly required
Includes necessary mounting hardware.
