Filter/Regulator/Lubricator (FRL)
$79.00
1.1 lbs.
Filter/regulator/lubricator (FRL). Diecast aluminum body with polycarbonate bowls, 1/4 in. NPT ports and 1/4 in. push-to-connect fittings, 60 SCFM.
FRL - Diecast aluminum body with polycarbonate bowls, 1/4 in. NPT ports and 1/4 in. push-to-connect fittings, 60 SCFM.
- Regulating Range: 7-125 PSI (0.5-8.5 kgf/cm2)
- Max. Operating Pressure: 150 PSI (9.9 kgf/cm2)
- Operating Temperature: 40-140°F (5-60°C)
- Filter Precision: 40 Micron
- Includes 1/4 in. push to connect fittings already installed
