Haimer Zero Master - Analog (Inch)
$579.00
Haimer Zero Master - Analog Dial Display (Inch) with 10 mm shaft diameter
Please select one of the holders listed below with your purchase (unless you already own one). This is required for use of this product.
Professional edge finder with analog display for fast and precise locating of edges and surfaces in X, Y, and Z.
  • Inch Display Dial
  • Nominal measuring accuracy +/-0.0005 in.
  • 10 mm shaft diameter.
  • Replaceable Tips
  • Made in Germany.
  • Mfg. PN 80.960.00.IN
