Heavy Duty Flexible Roller Table
$365.00
83 lbs.
Maximize efficiency and convenience to improve the workflow of your shop with this flexible roller table that can expand up to 54 in. in length.
Maximize the efficiency of your workspace and improve workflow with a multi-purpose, heavy-duty, flexible roller table as an outfeed stand or table extension for your bandsaw. Independent, fully-adjustable legs give you the flexibility to accommodate workspace needs while multiple tables connect for unlimited rolling capacity capable of maintaining up to 300 lbs. Smooth rollers allow you to easily move pieces while offering ergonomical support with increased convenience and productivity.
Features:
  • Collapsible design allows this roller table to fit in tight spaces or to be stored away with a small foot print.
  • Independently adjustable legs allow you to use this on almost any surface.
  • Polyurethane 4-1/4 in. (108 mm) diameter casters make it easy to move around and the locks make sure it stays where you want it.
  • Multiple roller tables can be connected for unlimited rolling capacity.
Compatibility:
  • AF50 Autofeed Bandsaw
Specifications
Number of rollers
Roller Size
19-1/2 in. long x 2 in. diameter (0.5 m x 50.8 mm)
Minimum table length
19-1/2 in. (0.5 m)
Maximum table length
54 in. (1.37 m)
Minimum table height
21-5/8 in. (0.55 m)
Maximum table height
31-1/2 in. (0.8 m)
Maximum weight capacity
300 lbs. (136 kg)
