Horizontal Mount for Universal Spindle Arm
$59.50
2 lbs.
The Horizontal Mount for Universal Spindle Arm allows mounting of a companion spindle, die grinder, or router to the Universal Spindle Arm
Use this base plate to mount a companion spindle, die grinder, or router to the Universal Spindle Arm as a horizontal spindle.*
- Useful for light machining/engraving on the end of long workpieces.
- Steel with black oxide finish. Includes necessary bolts and hardware to attach to the Universal Spindle Arm.
*Includes 0.75" spindle mounting hole (sized for Proxxon IB/E). Designed to be machined to 1.50" max diameter, as needed.
