Hypertherm cartridge: SmartSYNC or adapter 85A mechanized cutting
$64.95
Only 3 left
Hypertherm Part Number: 428934
If using with a non-SYNC plasma source PN 51736 Hypertherm cartridge adapter is needed.
85A mechanized cartridges provide optimal production performance when cutting within the thickness range of 10 mm (3/8″) to 16 mm (5/8″) thick. Exceeding optimal thickness range can result in decreases in speed and cut quality. To maximize cartridge life and performance select the correct amperage cartridge for the workpiece you are cutting.
85A mechanized cutting cartridges are compatible with:
- SmartSYNC™ torches for the Powermax85/105 SYNC™ systems
- Duramax® torches using a torch adapter* for Powermax85®/105 systems.
- Mechanized cartridges can also be used on hand torches if cutting with a stand-off is desired.
