Leveling Caster Kit, 1000kg
$365.00
8 lbs.
Leveling Caster Kit raises compatible stands and worktables 2.5 in. (63.5 mm)
Need extra space in the shop? This leveling caster kit will allow you to easily move your machine around the shop or tuck it into the corner when you’re not using it. Comes with 4 swiveling leveling casters. These easy-to-use casters raise compatible stands and worktables 2.5 in. (63.5 mm). Each caster has an adjustable foot that locks the machine in place and can be used to level each corner of the machine independently.
Note: only recommended use for 24R CNC Router,1300PL Plasma Table and ZA6 Robot worktable/stand.
Specifications:
- 4 casters per kit
- M16 x 2 stud included with each caster
- 2204 lbs (1000 kg) max load rating per caster
- 4409 lbs (2000 kg) max load for all 4 casters
