Lifting Bar Kit
$249.00
17 lbs.
The Lifting Bar Kit provides safe and balanced lifting of our milling machines
For maximum safety and security, always lift our milling machines using an overhead method. The Lifting Bar Kit is designed for safe and balanced lifting with a hoist or other overhead method, and features:
  • 3/8 in. (9.5 mm) thick steel lifting bar
  • G80-rated, high-strength chain
  • High-strength shackles rated for a minimum weight of 1 T (900 kg)
  • 1100MX
  • 770MX
  • 1100M
  • 770M
  • PCNC 1100
  • PCNC 770
Requirements
  • 2 T (1800 kg) engine hoist or similar lifting apparatus
What's In the Box?
  • Chain
  • Clevises
  • Lifting eye
  • T-slot anchors
