Light Curtain Safety Device - Long Version
$589.00
4 lbs.
The ZA6 robot requires the presence of a safety input to function. The 51355 light curtain sender/receiver pair comes with mounting hardware and is pre-wired with an M12 connector for use with the ZA6’s safety input.
- Dimension: 1.43 x 1.18 x 43.14 in. (36.5 x 30 x 1096 mm)
- Working distance between transmitter and receiver: .78 - 118.11 in. (20mm-3000mm).
- Detection resolution (minimum detected size): 1.96 in. (50mm)
- Response time: 10ms – 65ms
- Enclosure rating: IP65
Specifications:
- Effective Aperture Angle: Less than 5 degree at 118.11 in. (3m)
- Electrical specification
- Environmental resistance:
- Ambient light: Incandescent lamp: 3,000 lux max., fluorescent lamp : 3,00 lux max., Sunlight: 10,000 lux max.
- Operating ambient temperature: -4° - 140°F ( -20℃-60℃ ) - (No freezing)
- Operating relative humidity: 35% to 85 % RH (No condensation)
- Pre-wired for use with ZA6 robot
What’s in the box:
- Sender/receiver pair
- Mounting brackets
- Mounting T studs
- 10m cable with M12 connector
