Manual Oil Pump
$115.00
1.5 lbs.
Manual oil pump for the 1100M, 1100MX, 770M, 770MX, 8L and 15L Slant-PRO.
This manual oil pump delivers controlled amounts of lubricant to multiple locations on the machine. Lubricate ways on X-. Y- & Z-Axis. Requires manual pumping (x3) per 8 hour shift. Not recommended for unattended machining.
For use on the 1100M, 1100MX, 770M, 770MX, 8L and 15L Slant-PRO. Also compatible with the PCNC 770.
