Metric Thread Spiral Flute Tap Set – TiCN-Coated
$159.00
0.4 lbs.
Only 3 left
Multi-purpose TiCN-coated set of six spiral flute taps in sizes from M3 to M12.
This tap set includes the most common metric thread sizes in spiral flute geometry, designed for blind-hole threading and efficient chip evacuation. Each tap is manufactured from high-speed steel and finished with a Titanium Carbonitride (TiCN) coating, resulting in maximum durability across a wide range of workpiece materials including steels, stainless steels, and aluminum alloys.
  • Spiral Flute Design: Optimized for blind holes, pulling chips up and out of the hole.
  • TiCN Coating: Hard, wear-resistant surface (blue-gray to violet appearance) that increases tool life and heat resistance, ideal for steels, stainless steels, and abrasive materials.
  • Multi-Material Capability: Performs in carbon steels, alloy steels, stainless steels, aluminum, and non-ferrous alloys.
  • Complete Size Coverage: Includes the most frequently used metric taps in sizes from M3 to M12.
What's in the Box?
  • 1 - 33417 M3 X 0.5 Tap
  • 1 - 33419 M4 X 0.7 Tap
  • 1 - 33421 M6 X 1.0 Tap
  • 1 - 33423 M8 X 1.25 Tap
  • 1 - 33425 M10 X 1.5 Tap
  • 1 - 33428 M12 X 1.25 Tap
