MT-1 Live Center
$38.95
0.75 lbs.
The MT-1 Taper Live Center is for Light Duty Lathe Work
MT-1 Taper Live Center for light duty lathe work.  Can also be used for 4th Axis.
  • Ground Steel Construction
  • Maximum Speed Rating: 5000 RPM
  • Maximum Radial Load Rating: 70 lbs.
  • Overall Length: 4.6"
  • Stock Length: 2.4"
  • Point Angle: 60°
  • Diameter at base of Point: 0.7"
