Parallel Jaw Gripper Kit
$965.00
5 lbs.
Only 5 left
Set of two parallel jaw grippers mounted on pivot plate, includes control solenoids, mounting hardware, tools, screws, barrel connector, and tubing.
Set of two parallel jaw grippers mounted on pivot plate, with control solenoids, mounting hardware, and tubing. The plate on which the two 2-jaw grippers mount is configurable and allows both pneumatic grippers to be mounted in a variety of positions. Gripper jaws have non-marring polyurethane pads.
Specifications:
  • Stroke - 0 in. to .394 in, (0mm-10mm)
  • Jaw adjustment range - (clamping on outside of part) :
    • Smallest outer diameter - 0.174 in. (4.4mm)
    • The largest outer diameter - 3.0315 in. 77mm
  • Jaw adjustment range (clamping on inside of part):
    • Smallest inner diameter - 1.338 in. (34mm)
    • Largest inner diameter - 4.213 in. (107mm)
  • Clamping force (at 90 PSI):
    • Inner clamping force - 66N
    • Outer clamping force - 42N
What’s in the box:
  • Two 2-jaw grippers with adjustable jaws
  • Mounting plate to attach grippers to ZA6 tool flange
  • Solenoids with mounting plate, M12 connectors to control the grippers
  • Assorted fasteners to mount the grippers to the tool flange, the solenoids to the robot electrical cabinet
  • Tools, screws, and barrel connector
  • 4mm pneumatic tubing
