Passive Probe, M12 connector
$649.00
The Passive Probe, for use with 1500MX and 770MX mills with ML serial numbers, is an affordable probe for edge finding and basic probing procedures, suitable for hobbyist/occasional use.
Our passive probe is an affordable option for occasional and hobby use, suitable for edge finding and other basic probing procedures.
  • Normally closed sensing logic
  • Compatible with Renishaw M4 Stylus family
  • Stainless steel probe tip
  • Interfaces with machines mill using a M12 connector.
  • 1500MX CNC Mill
  • 770MX CNC Mills sold after December 1, 2025 with serial number starting with ML.
  • Replacement tip PN 51781
Note: Holder not included - select TTS or BT30 holder for your application. BT30 holder requires pull stud.
*This product is compatible with the 1500MX CNC Mill or any 770MX sold after December 1, 2025 with serial number starting with ML. Requires PathPilot or version 2.14.0 later. For other Tormach mills, select PN 50355.
Specifications:
Measuring Direction ±X, ±Y, & +Z
Repeatability 0.00059 in. (0.015 mm)
Maximum Over-Travel In +Z + .1968 in. (5.0 mm)
Maximum Angular Displacement ± 15°
Radial (X-Y) Trigger Force 30-60 g
Axial Trigger Force 500 ± 30 g
Water Resistance IP66
Shank size 10mm
