$649.00
The Passive Probe, for use with most Tormach mills*, is an affordable probe for edge finding and basic probing procedures, suitable for hobbyist/occasional use.
Our passive probe is an affordable option for occasional and hobby use, suitable for edge finding and other basic probing procedures.
  • Normally closed sensing logic
  • Compatible with Renishaw M4 Stylus family
  • Stainless steel probe tip
  • Interfaces with machines mill using a 5 pin DIN connector
  • Comes with 3 meter length cord
  • PCNC 440
  • PCNC 770
  • 770M
  • 770M+
  • 770MX sold before December 1, 2025 with serial number beginning with MF or MH
  • PCNC 1100
  • 1100M
  • 1100M+
  • 1100MX
  • Replacement tip PN 51781
Specifications:
Measuring Direction ±X, ±Y, & +Z
Repeatability 0.00059 in. (0.015 mm)
Maximum Over-Travel In +Z + .1968 in. (5.0 mm)
Maximum Angular Displacement ± 15°
Radial (X-Y) Trigger Force 30-60 g
Axial Trigger Force 500 ± 30 g
Water Resistance IP66
Shank size10mm
Note: Holder not included - select TTS or BT30 holder for your application. BT30 holder requires pull stud.
*This product is not compatible with the 1500MX CNC Mill or any 770MX sold after December 1, 2025 with serial number starting with ML.
