PathPilot Software Bootable USB Drive - Recovery Media
$32.95
0.5 lbs.
The PathPilot v2.x Upgrade is for Tormach customers looking to upgrade from PathPilot v1.9.13 to PathPilot v2.x
Can also be used when hard drive is replaced on controller.
Take your machining to a new level with PathPilot v2.x. With this major system upgrade, you can
  • Automatically transfer G-code files over Dropbox
  • Receive automatic updates for future releases
  • Streamline your machining experience with the updated interface
  • Use the new conversational profiling feature with the 15L Slant-PRO Lathe
If your system is already running PathPilot v1.9.x, we recommend that you first update to v1.9.13 to automatically back up and migrate your Tool Table data.
Tormach owners frequently purchase this USB as a backup PathPilot recovery/restore option.
You will need this recovery drive to install PathPilot if your hard drive crashes and needs to be replaced, this USB drive will install PathPilot on the new hard drive.
