PCNC 440 Equipped
PCNC 440 Equipped
PCNC 440 Mill This product is required for the machine. $7,995.00
PCNC 440 Stand $1,165.00
PCNC 440 Enclosure Kit $2,115.00
PCNC 440 Chip Pan $779.00
PCNC 440 Enclosure Door Switch Kit $179.00
Recommended items:
PCNC 440 Printed Manual $25.95
Related items:
Standard LCD Monitor $365.00
Touch Screen Kit $589.00
$55.00
$31.95
Waterproof Mouse $31.95
Controller Arm $465.00
Recommended items:
TTS™ Gauge Holder: 10 mm
Related items:
TTS™ Gauge Holder: 12 mm
Related items:
Flood Coolant Kit for PCNC 440 $639.00
1/4 in. Coolant Hose Accessory Kit w/Pliers $89.00
Recommended items:
LUBE CUBE Coolant Kit (115 Vac) for PCNC Mills $395.00
Pneumatic Hose Kit for Power Drawbar/ATC/Fogbuster $45.95
Coolube 2210, 1 Gallon, w/SDS $119.00
Recommended items:
8-Pocket Automatic Tool Changer for PCNC 440 $4,315.00
PCNC 440 Power Drawbar Kit $1,259.00
microARC 4 - 100 mm 4th Axis $3,884.00
4th Axis Driver and Installation Kit (PCNC 440) 4th Axis Driver and Installation Kit (PCNC 440)
ER40 Collet Set (8 Pcs.) - Inch $119.00
ER40 Collet Set (8 Pcs.) - Metric $119.00
Recommended items:
Workholding Setup Guide
4 in. CNC Vise $475.00
4 in. Parallel Set $65.00
Work Stop $65.00
Additional Options:
Strap Clamp Kit for 3/8 in. T-Slots (58 Pcs.) $95.00
SMW Fixture Tooling Plate for PCNC 440
Includes fixture tooling plate (PN 38208) bundled with mounting hardware and the most popular fixturing accessories (PN 52309).
Additional Options:
90° Spot Drill Kit
More Info In Stock
1/8 in. -90° Drills $9.95
1/4 in. -90° Drills $11.95
3/8 in. -90° Drills $15.95
1/2 in. -90° Drills $24.95
Thread Mill Kit
More Info In Stock
#8 x 1/2 in. x 1/4 in. Thread Mill $38.95
#12 x 5/8 in. x 1/4 in.  Thread Mill $79.00
5/16 x 3/4 in. x 5/16 in. Thread Mill $65.00
3/8 in. x 1 in. x 3/8 in. Thread Mill $79.00
TTS™ Saw Arbor: 1 in. $95.00
TTS™ Machinable Blank $38.95
TTS™ SuperFly Cutter Kit
Related items:
TTS™ Mini-Shear .750 in.
Related items:
Mini-Shear - .500 in.
Related items:
Related items:
Related items:
Shear-Hog - 2 in.
ADEH 431 (0.010 $255.00
Related items:
TTS™ Shear-Hog - 0.750 in.
Related items:
Related items:
Related items:
1-2-3 Block Set $42.95
X-Axis: 10 in. (254 mm)
Y-Axis: 6.25 in. (158.75 mm)
Z-Axis: 10 in. (254 mm)
Maximum Speed: 10.000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Tapping: Thread Mill
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
PATHPILOT® Controller
Assembly
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
