PCNC 440 Enclosure Door Switch Kit
$179.00
The PCNC 440 Enclosure Door Switch Kit provides an optional safety switch that limits the maximum spindle speed when PCNC 440 enclosure doors are open
For increased safety when the enclosure doors are open, install this optional switch that limits the spindle RPM and automatically pauses any G-code programs that may be running. Even when not running a G-code program, your PCNC 440 is still capable of movement — such as jogging or MDI commands — when the enclosure doors are open.
By default, this switch limits the spindle speed to 1000 RPM whenever the doors are open. You can change the limit value from 0 to 10,000 RPM.
Some assembly required.
  • PCNC 440 Enclosure Kit
What's In the Box?
  • Mounting hardware
