PCNC 440 Intermediate EDU Bundle
PCNC 440 Mill This product is required for the machine. $7,995.00
PCNC 440 Stand This product is required for the machine. $1,165.00
PCNC 440 Chip Pan This product is required for the machine. $779.00
PCNC 440 Enclosure Kit This product is required for the machine. $2,115.00
PCNC 440 Enclosure Door Switch Kit This product is required for the machine. $179.00
PCNC 440 Printed Manual $25.95
Standard LCD Monitor This product is required for the machine. $365.00
Flood Coolant Kit for PCNC 440 This product is required for the machine. $639.00
QualiChem XTREME CUT 251C This product is required for the machine. $75.00
PCNC 440 Power Drawbar Kit This product is required for the machine. $1,259.00
4 in. CNC Vise $475.00
Strap Clamp Kit for 3/8 in. T-Slots (58 Pcs.) $95.00
Haimer 3D Sensor - New Generation (Metric) $549.00
TTS™ Gauge Holder: 12 mm $42.95
X-Axis: 10 in. (254 mm)
Y-Axis: 6.25 in. (158.75 mm)
Z-Axis: 10 in. (254 mm)
Maximum Speed: 10.000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Tapping: Thread Mill
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
PATHPILOT® Controller
Assembly
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
