Power Drawbar Kit for 1100M / 770M
$1,515.00
23 lbs.
The Power Drawbar Kit supplies a pneumatic power drawbar that increases productivity and efficiency through push-button tool changes.
Manually changing your Tormach Tooling System (TTS) tools takes time and effort, which reduces productivity. Instead, use the pneumatic power drawbar for lightning-fast, push-button tool changes to keep you making chips, not spinning wrenches.
Features:
  • Floating pneumatic cylinder unclamps tools without stressing spindle bearings
  • Included filter-regulator-lubricator (FRL) unit cleans and conditions shop air for extended seal life
  • Easy installation kit has the drawbar up and running in minutes
Some assembly required.
  • 1100M
  • 770M
  • Tormach Tooling System (TTS) tools
Requirements
  • 90 psi to 120 psi (620 kPa to 840 kPa) compressed air source
What's in the Box?
  • 1/4 in. industrial-shape, quick-connect coupling
  • Cylinder assembly
  • Filter-regulator-lubricator (FRL) unit
  • Pneumatic lines
  • Valve assembly
