Proximity Sensor
$29.95
0.5 lbs.
Proximity sensor pre-wired with M12 connector for use with ZA6 robot digital inputs.
Proximity sensor pre-wired with M12 connector for use with ZA6 robot digital inputs to detect the presence (or absence) of metallic objects.
Specifications:
  • Overall dimension: 0 - 35mm, thread: M6 x 28
  • Wire length: 4m
  • Detection distance: 1mm
  • Repeated precision: 0.01mm
  • Input: DC 10-30V or AC 90-250 V
  • Consumption current: 15mA at 24VDC
  • Output: PNP, NC
  • Output current: DC 200mAX
    • Response frequency: 500Hz
  • Working temperature:-25-70℃
  • Waterproof: IP67
  • Shell material: stainless steel
