RCMT 2(1.5)MO Insert 10-Pack
$70.95
0.5 lbs.
The RCMT 2(1.5)MO Insert is a positive insert with chipbreaker that is recommended for steel machining
Package of 10 RCMT 2(1.5)MO Carbide Turning Inserts. Positive Inserts with Chipbreaker. Recommended for Steel Roughing.
  • Designation: RCMT 2(1.5)MO
  • Shape: Round (R)
  • Clearance Angle: 7° (C)
  • Tolerance: Class M (M)
  • Type: Single-Sided (T)
  • Insert I.C.: 6mm (2)
  • Thickness: 0.094 in. (1.5)
  • Corner Radius: Round (MO)
  • Grade (ISO): P5
  • Coating: TiCN
  • Chipbreaker: General Purpose
  • Application: Steel
