Replacement OEM Coolant Pump 115VAC for PCNC 1100 / PCNC 770 / PCNC 440 / 15L Slant-PRO
$239.00
9 lbs.
Replacement OEM Coolant Pump for PCNC 1100, PCNC 770 , PCNC 440, and 15L Slant-PRO Lathe
Replacement OEM pump for PCNC 1100, PCNC 770, PCNC 440., and 15L Slant-PRO Lathe.
  • Power: 75 W (1/10 HP)
  • Volume: 12 L/min (3 GPM)
  • Full Load RPM: 3240 RPM
  • Voltage: 115 VAC
  • Phase: Single Phase
  • Frequency: 60 Hz
  • Full Load Current: 0.8 A
  • Winding Insulation: Class B
  • Enclosure: IP 44
