RH Turning and Facing Holder for 1/2 in. Square Tool
$305.00
0.9 lbs.
Only 4 left
1/2 IN, RH Turning and Facing Holder for 15L lathe
Turn and face with the same cutting tool and cut down on tool changes. Includes clamp for direct to riser block table mount.
  • Solid positive lock minimizes chatter and harmonics
  • Accepts 80 deg diamond inserts
  • Right-handed cutting
  • For use with PN 33326, Riser for 1/2 in. Center Gang Blocks
