Shero Test Product
Shero Test Product
xsTECH Pro $10,795.00
Includes xsTECH Pro with automatic tool changer, cutting tools, toolholders, workholding, electronic tool setter, example projects and introductory curriculum.
xsTECH Pro
xsTECH Pro
xsTECH Pro with Stand $12,194.00
Includes everything in the xsTECH Pro plus a heavy-duty stand with integrated tool storage, locking wheels, and leveling feet.
xsTECH Pro
xsTECH Pro
xsTECH | xsTECH Pro Stand
xsTECH Pro with Robot $12,194.00
Includes everything in the xsTECH Pro plus 2 stands and a Dobot collaborative robot arm with electric gripper, mounting hardware, and robotics curriculum.
xsTECH Pro
xsTECH Pro
TTS™ Set Screw Holder: 10mm $34.00
1100M/M+/MX PathPilot Operator Console $1,795.00
$31.95
Waterproof Mouse $31.95
$55.00
Additional Options:
PathPilot Controller
PathPilot Controller $520.95
$31.95
$55.00
Touch Screen Kit $589.00
Standard LCD Monitor $365.00
Controller Arm $465.00
Additional Options:
Recommended items:
1-2-3 Block Set $42.95
Stop-Loc Setup Tool $22.95
SMW Fixture Tooling Plate for 1100 Mills $2,308.95
Recommended items:
1100 Fixture Tooling Plate Accessory Kit $659.00
30 mm Wrench for TTS™-ER20 Nut $11.95
Socket, BT30 Pull Stud $58.95
ER20 Collet - 1/8 in. $16.95
ER20 Collet - 1/4 in. $12.95
ER20 Collet - 3/8 in. $12.95
Recommended items:
Face Mill - 38 mm $245.00
Recommended items:
Recommended items:
SprutCAM / ENCY OEM Standard $1,509.00
More Info In Stock
SprutCAM OEM Advanced $2,695.00
More Info In Stock
16oz Travel Mug, Charcoal, Matte $35.95
12-Pocket Automatic Tool Changer for the 1100M $6,475.00
microARC 4 - 100 mm 4th Axis
remove
$3,934.00
4th Axis Driver and Installation Kit (M/MX*)
microARC 4 Subplate $145.00
Additional Options:
11% OFF 1100MX + ACCESSORIES
As a part of our overstock promotion, now through October 31, get 11% off your entire purchase when you buy a Tormach 1100MX CNC Mill. That includes everything you add to your cart: automatic tool changer, microARC 4 - 4th axis, tooling, fixturing, and even the AF50+ Bandsaw. Whether you're upgrading your shop or just getting started, now is the perfect time to invest in powerful, professional-grade CNC equipment.
Offer ends October 31, 2025 or while supplies last.
Now through September 30 - save 11% off on any 1100MX and accessoriesNow through September 30 - save 11% off on any 1100MX and accessories
TTS™ CNC Operator Set with Tormach Tool Assistant This product is required for the machine. $21.00
1500MX CNC MILL TECHNICAL SPECIFICATIONS
X-Axis: 19.7 in. (500 mm)
Y-Axis: 13.8 in. (350 mm)
Z-Axis: 14 in. (356 mm)
Spindle Nose to Table: 3.7-17.7 in. (96-450 mm)
Continuous Power: 4 hp (3 kW)
Peak Power: 6hp (4.5 kW)
Spindle Speed: 250-10,000 RPM
Spindle Taper: BT30 (sealed bearing)
Thread Machining: Rigid Tapping
Maximum Feed Rates
X- and Y-Axis: 1,200 IPM (30.5 m/min)
Z-Axis: 600 IPM (15.2 m/min)
Power and Air
Power Required: Single-Phase 230 Vac*, 50/60 Hz, 30A breaker**
Plug Type: NEMA L6-30P
Air Required: 90-120 psi
*±10%, best performance at 240 vac, **Additonal outlets may be required for optional accessories
Table Size: 35 in. × 12.75 in. (0.9 m × 0.3 m)
Typical System Footprint: 86 in. × 104 in. × 94 in.(2.2 m × 2.6 m × 2.4 m)
Typical System weight: 2800 lbs. (1270 kg)
Maximum Weight on Table: 300 lbs. (136 kg)
Performance
Testing: Ballbar testing on every machine
Key Components
Frame: Bonded epoxy granite base and column castings
Ways: Linear rails
Motion System: EtherCAT control system
Shipping
Pallet Weight: Factory Assembled: 3210 lbs. (1456 kg) / Self Assembled: 2650 lbs. (1202 kg)
Crate Dimensions: Factory Assembled: 67 in.(D) × 73.25 in.(W) × 85 in.(H) (1.7 m × 1.86 m × 2.16 m) / Self Assembled: 61.5 in.(D) × 57 in.(W) × 86 in.(H)(1.56 m × 1.45 m × 2.18 m)
Optional Accessories
16-pocket automatic tool changer (ATC)
microARC 6 – 6 in. (150 mm) 4th axis rotary table
36-gallon flood coolant tank and manual sprayer
Automatic enclosure washdown system
Wireless probe and tool setter
MQL system
Through-spindle coolant
Mist collector
Chip conveyor system
1-year warranty against defects in material and workmanship. Extended warranty available.
Maximum Feed Rates
Power and Air
Performance
Key Components
Ways: Linear rails
Shipping
Crate Dimensions: Factory Assembled: 68 in. × 74 in. × 89 in. (1.7 m × 1.9 m × 2.3 m) / Self Assembled: 54 in. × 58 in. × 89 in.(1.4 m × 1.5 m × 2.3 m)
MQL system
Mist collector
Travels:
Spindle Taper: BT30
Maximum Feed Rates
Power and Air
Power Required: Single-Phase 230 Vac, 50/60 Hz, 30A breaker
Performance
Key Components
Ways: Linear rails
Shipping
Please Note: The customer must have a forklift or loading dock to unload the crate.
MQL system
Mist collector
Chip conveyor system (under development)
Tormach Troubleshooting
LOOKING FOR HELP WITH YOUR 1500MX?
Visit the Tormach Support Site to find Manuals, Technical Documents, Datasheets, Service Bulletins, The Knowledge Base and Troubleshooting Guides.
View Our Support Section
