Shim Kit for Heavy Duty Gang Blocks
$79.00
0.5 lbs.
The Stainless Steel Shim Kit for Heavy Duty Gang Block Tooling is for the Tormach 15L/15LX Lathe
Shim kit for adjusting Heavy Duty Gang Blocks to spindle center line on Tormach 15L/15LX lathe.
  • Stainless Steel
  • 18 Pieces; 3 each of the following: .001 in., .002 in., .004 in., .005 in., .010 in., .025 in.
  • Use with the following PNs: 33205, 33206
