Rapid Turn Subplate
$145.00
5 lbs.
Only 2 left
Saunders Machine Works Rapid Turn Subplate
10.23 in. x 7.45 in. x .575 in. 6061 Aluminum Mounting Plate for Tormach RapidTurn. Plate is reversible for +X or -X mounting location. Plate is designed to mount directly to an SMW fixture plate and not the machine table. This plate is a replacement to the stock Tormach mounting plate.
Includes hardware for mounting to SMW Fixture Plates. Existing hardware is intended to be transferred from stock Tormach subplate when mounting the RapidTurn to the SMW subplate.
Tormach RapidTurn can remain mounted to the subplate when removed from the machine for simpler setup. Subplate is designed to be aligned using user-provided dowel pins OR SMW Diamond Pins in the SMW fixture plate for easy alignment and repeatability.
