Solenoid Kit - two solenoid valves for 6mm pneumatic tube on backing plate with M12 connector for use with ZA6
$539.00
1.2 lbs.
Only 2 left
Solenoid Kit - 2-valve 24VDC solenoid kit for 6mm pneumatic tubing on backing plate with M12 connector for use with ZA6
This kit includes two 24VDC solenoid valves with push-to-connect fittings and M12 electrical connectors for plug and play connection to the ZA6 robot outputs and pneumatic gripper accessories. Mounting plate with holes spaced to match threaded PEM fasteners allows you to mount this to the side of the ZA6 electrical cabinet. It is similar to the 39433 24V solenoid Kit but includes 6mm push-to-connect fittings (for use with 1/4 in. or 6mm pneumatic tubing) and a push-to-connect cap for one of the outlets.
This product will control any pneumatic device that uses 6mm pneumatic tubing but was specifically designed to work with the 51357 Sponge Cup Gripper product.
Specifications:
  • Type: Two-position valves
  • Input voltage: 24VDC±10%
  • Rated power: 3W per valve
  • Pressure:0.15-0.8MPa
  • Working temperature:-20-70℃
  • Waterproof: IP67
