Storm Vacuum Pump for 24R Kit
$3,120.95
Quickly and easily hold down flat sheet goods for processing on the 24R with the Storm Vacuum Pump for the 24R. Simply place your flat material on top of the 24R’s vacuum table and clamp it in place with the push of a button. Includes an inline canister filter to protect the vacuum pump motors form dust as well as all of the fittings and hoses needed to install the vacuum pump on the 24R.
Features:
  • Solid Steel Design
  • Integrated Vacuum Gauge
  • Durable Powdercoated Finish
  • Integrated Pressure Relief System
  • Sound Dampening Base with Exhaust Port
  • Power Switch with Circuit Breaking Technology
  • High Flow Air Cooling System with Replaceable Filter
  • 2 Long Life High Performance Vacuum Motors
Some assembly required.
  • 24R CNC Router
Requirements
  • Single Phase 220 - 240 VAC 50/60Hz / 20 Amps
Specifications
  • 200 CFM
  • 9.5 - 10 inHg Sealed Vacuum
  • 2" Threaded Steel Intake Port
  • Dimensions: 18.5 in. x 17.5 in. x 17.5 in.
  • NEMA 6-20P Plug (USA and Canada Spec)
  • Single Phase 220 - 240 VAC / 20 Amps
What’s In the Box?
  • Storm Vacuum Pump by Black Box Vacuums
  • PN 53802 Inline Canister Filter
  • PN 53803 Storm Vacuum Adapter Kit for 24R
Note: While this vacuum can run on as low as 208VAC, we recommend the Buck-Boost Transformer to bring the input voltage up to 230VAC, maximizing it’s performance.
Bundle
* Required Fields
Total Package Price
Summary
