PCNC 770 INSTALLATION
The following list of documents and videos are intended to assist with installation of your PCNC 770. The items are presented in the recommended order of installation. Tormach strongly urges customers to follow this sequence when installing your equipment in order to avoid installation conflicts. Please note that some of the installation instructions/videos may not be applicable for your particular set of equipment accessories.
UM10350: Tormach PCNC 770 (Series 3) Operator's Manual for PathPilot
Learn how to set up and safely operate a PCNC 770 Series 3 mill.
15.32 MB
pdf
Download
View in Browser
TD10407: PCNC 770 STAND ASSEMBLY
Learn how to assemble a PCNC 770 machine stand.
605.05 KB
pdf
Download
View in Browser
Tormach PCNC Unboxing (770 and 1100)
Since the PCNC 770 and 1100 setup is so similar, we have combined the steps into one video. When there are differences a notification will appear on the top of the screen. This video is not a replacement to the manual. Before installing either machine you
TD10406: PCNC 770 FLOOD COOLANT KIT
Learn how to install a flood coolant kit and backsplash on a PCNC 770 mill.
593.63 KB
pdf
Download
View in Browser
TD10384: MACHINE ARM INSTALL
Learn how to install a Machine Arm on a PCNC 1100 or PCNC 770 mill that doesn't have a full enclosure installed.
436.8 KB
pdf
Download
View in Browser
TD10038: AUTOMATIC OILER INSTALLATION - 115 VAC
Learn how to install and use an automatic oiler system on a PCNC 770 mill.
1.24 MB
pdf
Download
View in Browser
TD10358: QUICK-START GUIDE: PATHPILOT CONTROLLER
Learn how to set up a PathPilot controller for a PCNC 1100, PCNC 770, or PCNC 440 mill, and a 15L Slant-PRO lathe.
559.42 KB
pdf
Download
View in Browser
TD10128: PCNC 770 POWER DRAWBAR INSTALLATION
Learn how to install and use a Power Drawbar on a PCNC 770 mill.
2.62 MB
pdf
Download
View in Browser
UM10355: OPERATOR'S MANUAL: SERIES 3 AUTOMATIC TOOL CHANGER (ATC) FOR PCNC 770
Learn how to install and use a Series 3 ATC with a PCNC 770 Series 3 mill.
4.49 MB
pdf
Download
View in Browser
TD10560: Owner's Guide: M Machine Automatic Tool Changer (ATC) Retrofit for PCNC 770
Learn how to install and use an M machine ATC with a PCNC 770 Series 3 mill.
3.33 MB
pdf
Download
View in Browser
How to Align the Tormach ATC (Part 1 of 2)
Tormach Project and Electronics Engineer Daniel Rogge demonstrations the mounting and alignment procedure for the Tormach Automatic Tool Changer on the Tormach PCNC 1100.
How to Align the Tormach ATC (Part 2 of 2)
Tormach Project and Electronics Engineer Daniel Rogge demonstrates the mounting and alignment procedure for the Tormach Automatic Tool Changer on the Tormach PCNC 1100.
TD10374: Owner's Guide: 6 in. and 8 in. 4th Axis for PCNC 1100/PCNC 770
Learn how to install and set up a variety of 4th axis kits with PCNC 1100 or PCNC 770 mills.
2.68 MB
pdf
Download
View in Browser
How to Set Up a 4th Axis - Tormach CNC
Tormach's Mike Corliss demonstrates how to install and align the Tormach 4th Axis on the Tormach PCNC 1100 mill.
TD10258: CONTROL RELOCATION KIT
Learn how to relocate the power controls on a PCNC 1100 or PCNC 770 mill (when the full enclosure is installed).
1.39 MB
pdf
Download
View in Browser
TD10291: PCNC 770 FULL ENCLOSURE INSTALLATION
Learn how to install a Full Enclosure Kit on a PCNC 770 mill.
1.61 MB
pdf
Download
View in Browser
Tormach controls engineer, Daniel Rogge, walks through cutting your first part on a Tormach mill with the Conversational Programming in PathPilot.
