TNMG 332 Insert 10-Pack
$109.50
0.5 lbs.
The TNMG 332 Insert is a negative insert with chipbreaker that is recommended for Steel roughing
Package of 10 TNMG 332 Carbide Turning Insert.
  • Designation: TNMG 332
  • Shape: Triangle (T)
  • Clearance Angle: 0° (N)
  • Tolerance: Class M (M)
  • Type: Double-Sided (G)
  • Insert I.C.:3/8" (3)
  • Thickness: 0.187" (3)
  • Corner Radius: 0.031" (2)
  • Grade (ANSI/ISO): C6/P20
  • Coating: TiN
  • Chipbreaker: Roughing
  • Application: Steel
