Tormach xsTECH Aluminum Fixture Tooling Plate
$155.00
3.6 lbs.
Product Specifications
  • 12 in. x 5.95 in. x 0.575 in. 6061 Aluminum Fixture & Tooling Plate for Tormach xsTECH Routers.
  • Holes are 0.75in. on center. Every hole is tapped 1/4 in. -20.
  • This plate is intended for use on machines sold after February 2020. Early machines (pre-February 2020) use copper sleeve bushings for linear motion which are not compatible with this fixture plate. Some machines sold between February-October 2020 may have square-style linear bearings (see 3rd photo) which are compatible in addition to the current cylindrical-style linear bearings on machines after October 2020 (4th photo).
Note: Plate does not contain locating bores for 1/4 in. dowel pins.
This plate is meant to REPLACE the stock xsTECH table, not mount on top of the existing aluminum extrusion. Hardware is not included as existing hardware is meant to be reused. No additional accessories are required.
