TTS™ Collar: 3/4 in.
$32.95
0.6 lbs.
The TTS™ Collar: 3/4 in. is a TTS™ Tool Conversion Kit (Light Press Fit) - compatible with Tormach ATC
Kit can be used to convert many conventional tools with 3/4 in. shank into Tormach Tooling System tools.
  • Light Press Fit on .750 in. shaft (.748 in. +0/-.001 in. collar ID). No adhesive required, install with an arbor press (not included)
  • Steel Ring with Black Oxide Finish
  • Groove Geometry is compatible with Tormach ATC
