TTS™ ER Collet Tap Holder: ER16
$213.00
The TTS ER Collet Tap Holder: ER16 is a clutchless Tension/Compression tapping head.
ER collets range in size from 3/64 in. - 3/8 in. (1 mm - 10 mm)
  • Fits all ER16 collets
  • Alloy Steel TTS Toolholder
  • Outside Diameter: 1.06 in. (27 mm)
  • Installed Height: 3.8 in. (96 mm)
  • Thread: M22 x 1.5
  • Includes ER16 Collet Nut
  • Approximately Float: 0.75 in.
Note: Not compatible with PCNC 440 mills.
