TTS™-MT3 Collet & Drawbolt
$29.95
The TTS™-MT3 Collet & Drawbolt is a 3/4 in. TTS™-MT3 collet & drawbolt used to mount TTS™ toolholders to MT3 spindles or center holes
Use to mount TTS™ holders on the 8 in. (200 mm) rotary table for economical method to hold slender round bar for rotary machining. The center hole of the 8 in.(200 mm) rotary table has a #3 Morse taper.
The TTS™-MT3 collet uses a slightly modified geometry from standard MT3 collets for compatibility with the TTS™ holders. It features a 3/8-16 in. thread and can also be adapted to many native MT3 spindles (Draw bar not included).
