TTS™ SuperFly Cutter Kit
$205.00
TTS™ SuperFly Cutter Kit for the Deluxe Package. Fly Cutter kit with modern insert geometries, specially designed for maximum performance on 3hp spindles.
  • Adjustable between 2.6 in. to 3 in. Cutting Diameter
  • Includes tool bar for SEHT Insert
  • 1.8 in. (46 mm) Height
  • TTS™ Fly Cutter Body with ATC Geometry
Kit includes:
  • Fly Cutter Body
  • Tool bar
  • Two General purpose carbide inserts
  • Two polished carbide inserts for aluminum machining
  • Insert Screw
  • Wrench
  • Anti-seize
Note: For use in BT30 spindles, we recommend using a BT30 ER32 holder with a 3/4 in. ER32 collet.
Customize Your Package
Cutting Head
Inserts and Screws
* Required Fields
Total Package Price
Total Package Price TTS™ SuperFly Cutter Kit
Summary
