USB Bulkhead Port Assembly
$19.95
0.3 lbs.
The USB Bulkhead Port Assembly allows your to mount a USB connection port to the Deluxe Stand of your PCNC 1100, PCNC 770, or 15L Slant-PRO
This USB bulkhead cable kit lets you mount a USB connection port on the stand of your PCNC 1100, PCNC 770, or 15L Slant-PRO. One end of the cable can be mounted on the stand, while the other plugs into one of the USB ports on the controller.
- Compatible with the following PNs: 30297, 31191, and 34444
