xsTECH Pro Vacuum Workholding Kit
$215.00
4 lbs.
The xsTECH Pro Vacuum Workholding Kit is an accessory for the xsTECH PRO desktop CNC system, designed to provide fast, secure, and non-marring workholding for flat materials. This kit is ideal for technical education, prototyping, and advanced machining projects where quick part changeover and gentle clamping are required.
Key Features
  • Aluminum Vacuum Chuck: Precision-machined 150mm x 150mm vacuum chuck provides a flat, stable surface for holding sheet materials and delicate parts without mechanical clamps.
  • Venturi Valve System: Uses shop air (via included Venturi valve) to generate vacuum—no dedicated vacuum pump required.
  • Quick Setup: Includes all necessary fittings, tubing, and gaskets for easy integration with the xsTECH PRO and standard air compressors.
  • Non-Marring Hold: Ideal for plastics, woods, PCBs, and other materials where clamp marks are undesirable.
Benefits
  • Fast Part Changeover: Quickly load and unload parts for higher productivity.
  • Secure, Even Clamping: Holds parts flat and steady during machining.
  • Protects Delicate Materials: No risk of clamp-induced damage or distortion.
  • Easy to Install: Designed for plug-and-play use with the xsTECH PRO and standard shop air.
Specifications
  • Air Consumption: 1.55 CFM
  • Air Pressure Required: 90 PSI
  • Maximum Vacuum: - 13.3 PSI
  • Suction Flow Rate: 0.95 CFM
What's in the Box?
QTY. DESCRIPTION
1 150 mm x 150 mm Aluminum Vacuum Chuck (customized)
1 Venturi Valve
1 Vacuum One-Way Valve
3 m Vacuum Gasket
3 m 8 mm OD Vacuum Tubing
1 Quick Connect for Air Compressor
1 8 mm PTC Fitting (Quick Connector Adapter)
1 PTFE Tape
4 M6 x 10 mm SHCS
4 6 mm T-nuts
8 Fixture Pins, 6 mm diameter x 20 mm
