Mitee-Bite VersaGrip Steel Jaw Set For 6" Vises
$224.95
5.4 lbs.
VersaGrip™ vise jaws allow you to grip a wide range of odd shaped objects that you would otherwise not be able to hold in a vise.
NOT COMPATIBLE WITH TORMACH 5" VISES
This system can accommodate a wide range of part sizes as well as holding multiple parts in a single cycle. The hardened (51-53 RC) VersaGrip™ has penetrating teeth designed to bite into your workpiece preventing lateral and horizontal movement. These grips will hold flame cut parts, castings, even parts with a negative draft!
STEEL VISE JAW SET (Set includes 4 VersaGrips™ with M5 Screws)
| Part No. | Vise (metric) | A (metric) | B (metric) | C (metric) | D (metric) | E (metric) | |
| WITH MOUNTING HOLES | |||||||
| 32166 | 4”/6” (100mm/150mm) | 6.00 (150) | 1.88 (47.75) | 1.0 (25.4) | 2.5/3.88 (63.5/98.55) | .688/.94 (17.47/23.87) | |
