Mitee-Bite VersaGrip™ Steel Jaw Set For 4" and 5" Vises
$255.00
6 lbs.
VersaGrip™ vise jaws allow you to grip a wide range of odd shaped objects that you would otherwise not be able to hold in a vise.
COMPATIBLE WITH TORMACH 4 in. and 5 in. VISES
This system can accommodate a wide range of part sizes as well as holding multiple parts in a single cycle. The hardened (51-53 RC) VersaGrip™ has penetrating teeth designed to bite into your workpiece preventing lateral and horizontal movement. These grips will hold flame cut parts, castings, even parts with a negative draft!
STEEL VISE JAW SET (Set includes 4 VersaGrips™ with M5 Screws)
Vise (metric) 4 in. /6 in. (100mm/150mm)
A (metric) 6.0 in. (150 mm)
B (metric) 1.88 in. (47.75 mm)
C (metric) 1.0 in. (25.4 mm)
D (metric) 2.5 in. / 3.125 in. (63.5 mm/ 79.375 mm)
E (metric) .688 in. / .8 in. (17.47 mm / 20.32 mm)
