xsTECH CNC Router/Mill
xsTECH Router Package $4,535.00
4th Axis Kit for xsTECH and xsTECH Pro Routers $755.00
xsTECH Router Shipping Case $1,209.00
Additional Options:
xsTECH Router - 230V (Europe) $4,535.00
Additional Options:
Tormach xsTECH Aluminum Fixture Tooling Plate $155.00
xsTECH Cutting Tool Kit $239.00
Replacement set of the same tool kit included with every xsTECH purchase.
30° x 1/8 in. x 1-1/2 in. $20.95
45° x 1/8 in .x 1-1/2 in. $20.95
60° x 1/8 in. x 1-1/2 in. $20.95
90° x 1/8 in. x 1-1/2 in. $20.95
xsTECH TECHNICAL SPECIFICATIONS
X-Axis: 8.6 in. (220 mm)
Y-Axis: 6.3 in. (160 mm)
Z-Axis: 2.4 in. (61 mm)
Spindle Power: 120 W (0.12 kW)Brushless DC
Maximum Speed: 20,000 RPM
Spindle Taper: ER11
Noise Level (No Load Operation): <66 db(A)
Repositioning Accuracy: 0.004 in (0.10 mm)
Safety
*Starting in 2026, xsTECH machines are now UL certified and include a UL certification mark on the back of the unit.
Power Required: Single-Phase, 50-60 Hz
120 Vac (USA/Canada, PN 39177)
230 Vac (International, PN 50614)
Table Size: 12.6 in. × 5.9 in.(320 mm × 150 mm)
Typical System Footprint: 15.4 in. × 15.7 in.
(391 mm × 399 mm)
Overall System Height: 16.7 in. (424 mm)
Typical System Weight: 33 lb (14.9 kg)
Maximum Table Load Weight: 6.6 lb (3 kg)
1-Year Warranty against defects in material and workmanship.
