xsTECH Cutting Tool Kit
$239.00
Replacement tool kit for the xsTech Router
Kit contains one each of the following:
Part Number Description Cutting Diameter Flute Length Shank Diameter Overall Tool Length
39171 Spiral Ball Nose Up-Cut End Mill 2 mm 12 mm 4 mm 50 mm
39172 Spiral Down-Cut End Mill 4 mm 12 mm 4 mm 50 mm
39173 Spiral Compression End Mill 4 mm 20 mm 4 mm 50 mm
39174 Spiral Up-Cut Plunge End Mill 4 mm 12 mm 4 mm 50 mm
39176 Spiral Down-Cut Plunge End Mill 4 mm 12 mm 4 mm 50 mm
39165 Tapered Ball Nose End Mill 1 mm 10 mm 4 mm 50 mm
39164 Square End Mill 4 mm 6 mm 4 mm 50 mm
39161 Spiral 'O' Flute Up-Cut End Mill 2 mm 6 mm 4 mm 40 mm
