xsTech PRO Aluminum Fixture Plate
$225.00
7 lbs.
Only 2 left
xsTech PRO Aluminum Fixture Plate for use with xsTech PRO and Dobot MG400.
Easily located and fixture work holding or part locations using our anodized aluminum fixture plate. Fits on the xsTech PRO work table as well as a locating fixture for a paired automation cell. Uses standard M6x1 metric hardware on a 25mm square pattern.
Specifications:
  • Overall Dimensions - 300mm x 300mm
  • Hole pattern - 10x10 M6 threaded holes spaced 25mm on center
