xsTECH PRO Dust Collection Kit
$269.00
12 lbs.
The xsTECH Pro Dust Collection Kit is an accessory for the xsTECH PRO desktop CNC system, designed for efficient removal of wood dust, plastic chips, and other dry waste from inside the xsTECH Pro.
Key Features
- Open-source components: Includes a 3D-printed dust port and nozzle, specifically designed for the xsTECH Pro spindle and enclosure for optimal fit and performance. Designs are open-sourced for easy replacement or modification.
- Flexible compatibility: Works with customer-supplied shop vacuums or other vacuum systems.
- Durable construction: Industrial-grade flexible hose, components, and hardware ensure long-term reliability in classrooms or shops.
- Proven cyclonic separation: The Quick Click separator is tested in both domestic and commercial settings. Its wide-diameter, smoothed air stream maximizes cyclonic separation, ensuring dust and debris are deposited into the collection bin, keeping the air reaching your vacuum virtually clean.
- Baffle plate for fine dust: An internal baffle plate prevents fine dust from re-entering the vacuum, significantly enhancing the separation of small particles.
- Leak-proof, durable construction: Commercial-grade rubber gaskets and a heavy-duty HDPE 5-gallon pail ensure a leak-proof, robust solution. The separator base extends through the bucket lid for added stability and assembly integrity.
- Easy, secure emptying: The heavy-duty threaded lid with a ratchet locking feature simplifies and secures the emptying of collected debris—no more damaged pry lids or accidental spills during transport.
- Cleaner, safer workspace: Reduces airborne dust and chips, improving safety, machine longevity, and creating a healthier environment.
Benefits
- Cleaner Workspace: Reduces airborne dust and chips for improved safety and machine longevity.
- Supports All Materials: Essential for machining wood, plastics, and non-ferrous metals.
- Quick Setup: Designed for plug-and-play use with the xsTECH PRO enclosure and spindle head.
What's in the Box?
- Rugged 5-gallon cyclonic separator system with quick-release lid for easy emptying
- Durable 1.5 in. diameter flexible dust hose with quick-connect system
- Nozzle
- Dust Port
