xsTECH Pro 24VDC Contactor Box
$109.00
2 lbs.
The xsTECH Pro 24V Contactor Box (PN: 54225) is an external relay interface designed for the xsTECH PRO desktop CNC system, especially for use with the Robot Kit and other automation accessories. It enables safe, reliable switching of 24VDC signals to control external devices such as collaborative robots, grippers, and automated doors. The box is essential for integrating the Dobot MG400 robot and is included with every robot package.
Key Features
  • 24VDC Relay Switching: Provides isolated, dry-contact relay switching for 24VDC control circuits—ideal for robot I/O, grippers, and automation tasks.
  • Plug-and-Play Integration: Pre-wired and ready to use with the xsTECH PRO and Dobot MG400 robot; connects via standard 4-pin connectors.
  • Industrial-Grade Components: Uses CE and UL-listed relay contactor and robust enclosure for safety and reliability.
  • Compact & Durable: Lightweight (1.5 lbs), with a small footprint (9 x 5 x 7.5 in) for easy placement near the machine or robot cell.
  • Tested & Approved: Validated by Tormach engineering for use in educational and industrial environments
Benefits
  • Enables Automation: Required for robot integration, automated doors, and other 24VDC-controlled accessories.
  • Safe & Reliable: Provides electrical isolation and robust switching for critical automation tasks.
  • Easy to Deploy: No special wiring or configuration required—simply connect and use.
What's in the Box?
  • 1x xsTECH Pro 24V Contactor Box (assembled)
  • Relay contactor (24VDC coil, DPDT or similar)
  • Plastic enclosure with cord grip
  • 4-pin screw terminal and connector for 24V coil voltage
  • 6 ft 4-conductor cable (USB or equivalent)
  • Flyback diode for relay protection
  • All necessary internal wiring and hardware
