xsTech Pro Machine Tending Project Kit
$215.00
Kit contains:
  • 1 - 1.5 Inch Natural Wood Slices Unfinished Round Wood Coins, 50 per Pack.
  • 1 - Backstop, 3D-Printed
  • 2 - Hose Bracket, 3D-Printed
  • 1 - Valve Plate, 3D-Printed
  • 2 - Flow Control Valve, SCF 1/4 in., 1/4 in. Tube OD x 1/4 in. Tube OD Air
  • 10 - Tubing, Pneumatic, 1/4 in. OD 1/3 in. ID, Opaque
  • 12 - Screw, Socket Cap, M6x1.0 - 20mm
  • 4 - Screw, Socket Head Cap, M6x1.0x012, Black Oxide
  • 2 - Gripper Fingers, 3d-Printed, w/2 Inserted Dowels
  • 4 - Screw, Round Head Phillips, Thread-Forming, M3 x 20mm, Zinc-Plated Steel
  • 2 - Screw, Headless Shoulder, 4mm diameter,4mm length
  • 2 - Screw, Socket Head Cap, M6x1 - 30, Steel, Black Oxide, Full Length Thread
  • 1 - Pneumatic Air Cylinder, 10mm Bore, 25mm Stroke, Aluminum
  • 4 - Screw, Socket Head Cap, M03 x 0.5 x 08
  • 1 - Engraving Router Bits, 20 degrees, 1/8 shank, 2 flutes, 0.1mm tip, SS, 5 pieces
  • 1 - Solenoid, xsTech Pro
  • 1 - Cylinder Strap Clamp, 3D-Printed
  • 1 - Cylinder Stop, 3d-printed
  • 1 - Token Grid Fixture, 3D-Printed
  • 6 - Dowel Pin, 4 mm x 20 mm, 52100 Alloy Steel
